Maya DAE <-> XSI DAE
joschy
Post by joschy » 11 Feb 2012, 12:54
Hi there,
we use sometimes Maya for animate 3D stuff. But when Maya export it as FBX DAE, no animation data is read from Ventuz. The same scene exported via XSI work. It seems to me, that the DAE reader from Ventuz don´t like Maya. Why?
Re: Maya DAE <-> XSI DAE
Post by Karol » 13 Feb 2012, 09:59
Actually our Collada importer has no prejudices :)
Could you post a simple example for an animation export from Maya?
joschy
Post by joschy » 14 Feb 2012, 11:14
Hi Karol,
attached are two scenes. One is the original from Maya and the second exported with XSI.
Cubes_v02.zip
Sample Maya and XSI export
(264.63 KiB) Downloaded 856 times
Post by Karol » 14 Feb 2012, 16:44
Hi joschy!
The Collada exporter in Maya exported the animations as a matrix animations but Ventuz cannot animate matrices thus we do not import it.
In XSI the animations are exported with separated animations per X/Y/Z-translation channel.
I would give the ColladaMaya plugin a try; or check if you can change the animation export in the FBX DAE exporter.
blaufisch
Post by blaufisch » 15 Feb 2012, 10:45
exporting animation from maya to collada is a bit tricky!
Try using the free plugin openCollada instead of FBX DAE.
Then the animation will be exported in a way that Ventuz is able to import it again.
But: don't use different materials on one animated object, this
will be messed up!
greets ralf
joschy
Post by joschy » 15 Feb 2012, 12:00
Hi Karol,
thank´s for the explanation, makes sense...
I will have a look at the exporter settings.
joschy
joschy
Post by joschy » 15 Feb 2012, 12:07
works now 8-)
Under the Collada section is a Single Matrix Option. After disable it, it works... Great!
Thank you for the hint
ErikB
Post by ErikB » 18 Feb 2012, 00:01
As an ex-Softimage employee, I see nothing wrong with this. XSI is simply superior in every fashion, and the solution to your problem is simply to use the superior product :D
iotek
Post by iotek » 04 Aug 2012, 14:33
Hi
I'm also trying to import an animation from maya using the collada format.
I'm using Maya 2011 and have created a simple animation with a plane animating along a curve. the animation has been baked into keyframes for the translation and rotation values. I've tried using both the maya FBX_DAE and the OpenCollada exporter with all sorts of different export configurations....and I still cant seem to get the animation to export into Ventuz.... :?:
Ive added some screen grabs of the settings ive been using and the.dae file
any advice would be much apreciated :)
chris
iotek
Post by iotek » 04 Aug 2012, 14:35
Can't seem to attach the .DAE file to my post :(
