Make a mask on a reflective ground
Carlos
Post by Carlos » 09 Apr 2013, 12:32
Hey there!
I've followed the help topic on how to create a mirror reflection and it actually looks quite good actually!
My only problem is that the contents on the scene are gonna be moved around with touch translation nodes, and I can't find a way to make a stencil mask so that the reflection is only seen "below" the plane I used as a floor and the content is only rendered "above" that floor.
I don't know if I've been clear enough, but I hope you can understand what I mean! :)
Thank you in advance
Re: Make a mask on a reflective ground
Post by Karol » 09 Apr 2013, 13:34
Check out the attached archive!
Hope this is what you need! Works only in Ventuz Pro because it needs Stencil nodes.
stencil_reflection.vza
(21.26 KiB) Downloaded 485 times
Carlos
Post by Carlos » 09 Apr 2013, 14:51
Wow. Karol, thank you so much for your effort, but it's clear that I didn't explain myself :)
I did that, as told by the help file, and that makes reflection only render where the floor is actually displayed, but that's not what I meant.
I'm gonna follow Alex's advice and post a couple of images here:
As you can see, the reflection looks great, but when my content goes beyond the wall, the content and the reflected content collides...
Is there a way to avoid these, making the top content only visible on the upper side of the floor, and the reflection only visible on the lower side? Did I make sense this time? :?
Carlos
Post by Carlos » 10 Apr 2013, 13:12
Will try and let you know!
Can't be more grateful :)
