Hi
- I want to make a snapshot in the Layer Pixelsize.
- I am using the Snapshot Framebuffer in my layer.
- I changed the Layer Properties to pixels and as long as i don't bind the Width propertie to any variable, the Snapshot frambuffer is showing the right resolution.
- But if i connect any variable for eg. to the width propertie it shows the wrong size!
Greetings
Christian
Re: Snapshot Framebuffer
Attached a simple Scen with two Layers
Both are internal the same. In one i can adjust the Layer Properties manualy and the Texture Size of the Frame Buffer will change. The other one, where the Layer properties are bound to a variable the Texture size stays the same.
Greetings
Christian
Greetings
Christian
- Screenshot_2.vzs
- (16.82 KiB) Downloaded 379 times
Hi Ventuzians
Any Feedback?
Greetings
Christian
Any Feedback?
Greetings
Christian
