Snapshot Framebuffer
Post by chriss0212 » 17 Mar 2020, 19:21
Hi
- I want to make a snapshot in the Layer Pixelsize.
- I am using the Snapshot Framebuffer in my layer.
- I changed the Layer Properties to pixels and as long as i don't bind the Width propertie to any variable, the Snapshot frambuffer is showing the right resolution.
- But if i connect any variable for eg. to the width propertie it shows the wrong size!
Greetings
Re: Snapshot Framebuffer
Post by chriss0212 » 19 Mar 2020, 17:02
Attached a simple Scen with two Layers
Both are internal the same. In one i can adjust the Layer Properties manualy and the Texture Size of the Frame Buffer will change. The other one, where the Layer properties are bound to a variable the Texture size stays the same.
Greetings
Screenshot_2.vzs
(16.82 KiB) Downloaded 380 times
Post by chriss0212 » 06 Apr 2020, 10:45
Hi Ventuzians
Any Feedback?
Greetings
