How to control DMX via serial port?
eguana
Post by eguana » 10 Oct 2018, 14:33
Hi guys, I have an FTDI controller USB->RS485.
I want to control through the serial port. But DMX have Break on start. (BreakOn,BreakOff) How to send byte array via Serial?
Ventuz manual says that "SMPTE Breaks are currently not supported."
here is a library under C# FTD2XX_NET.DLL, is it possible to use it for data transfer????
THanks
FTD2XX_NET_v1.1.0.zip
(34.48 KiB) Downloaded 450 times
FTD2XX_NET.zip
(30.98 KiB) Downloaded 414 times
Re: How to control DMX via serial port?
Post by Karol » 10 Oct 2018, 15:35
Hi equana!
Can't you use the build-in DMX nodes?
eguana
Post by eguana » 10 Oct 2018, 16:02
Hello Karol, I still do not understand the scheme of work DMX node. i just study artnet, but i work with serial a lot of time.
Thank you Karol :)))
Eric_RD
Post by Eric_RD » 22 Oct 2018, 14:01
If you want to stick to your Assembly:
Add it to the GAC (via VS Developer console or Powershell) and use a Script.
See Scripting and Advanced Scripting in Manual for Details.
I recommend the DMX Node(s)...works fine for me.
The Serial Node is useful for very basic controlling mechanisms DMX exceeds that.
Regards, Eric
