Hi guys, I have an FTDI controller USB->RS485.
I want to control through the serial port. But DMX have Break on start. (BreakOn,BreakOff) How to send byte array via Serial?
Ventuz manual says that "SMPTE Breaks are currently not supported."
here is a library under C# FTD2XX_NET.DLL, is it possible to use it for data transfer????
THanks
How to control DMX via serial port?
- FTD2XX_NET_v1.1.0.zip
- (34.48 KiB) Downloaded 450 times
- FTD2XX_NET.zip
- (30.98 KiB) Downloaded 415 times
Re: How to control DMX via serial port?
Hi equana!
Can't you use the build-in DMX nodes?
Hello Karol, I still do not understand the scheme of work DMX node. i just study artnet, but i work with serial a lot of time.
Thank you Karol
Thank you Karol
If you want to stick to your Assembly:
Add it to the GAC (via VS Developer console or Powershell) and use a Script.
See Scripting and Advanced Scripting in Manual for Details.
I recommend the DMX Node(s)...works fine for me.
The Serial Node is useful for very basic controlling mechanisms DMX exceeds that.
Regards, Eric
Regards, Eric
