						Post
								by chriss0212 » 08 Aug 2018, 10:53
			New Feature, new request
Now we have the awesome new touch feature in the particle system... Don't know if maybe already possible:
Take a string array labeling the particles! Using something like the flipbook as array indexer
Greetings
Christian
						Post
								by chriss0212 » 08 Aug 2018, 11:19
			Mhhh...
thought i could use the strip loader in combination with a render target... but where can i find the strip loader?
Greetings
Christian
						Post
								by chriss0212 » 08 Aug 2018, 14:27
			OK... found the Strip loader... but:
- is it possible, that we can't feed it with a off screen render target?
Thank's and greetings
Christian
																			 zding
						Post
								by zding » 29 Aug 2018, 11:36
			How to add a set of materials to particles?I hope to have this function.
																			 VincentPix
						Post
								by VincentPix » 25 Sep 2018, 13:42
			Hi Chriss,
Same problem here. Did you have an answer or did you find something for a "live feed" strip loader for particles ?
Greetings
																			 VincentPix
						Post
								by VincentPix » 11 May 2021, 10:55
			Hello
Does someone found a solution for this problem of a live feed (render target or video) in the flipbook / striploader of the Particle system ?
The StripLoader only take still images.
The UV mapping '2D Strip Mapper' cannot be accessed from the animation parameter with a 'flipbook control'.
We can't generate UVmap for the sprites through the 'Data Animation'.
Am i wrong
Is there a trick to achieve that ?
If not : Will you develop something for a future update ?
Thank you
