I have to use an advanced text node to build some content. Is the only option to use the colours from within the node? It totally ignores a colour node placed before it. With a standard text node, I can set the material node to have a little specular
in the colour. Not possible with advanced text node?
Font colour and enriched text mode
Re: Font colour and enriched text mode
Further to my font explorations. I cant get this
to work by using the "[" (left bracket)to change part of the text to Italic.
There is no example in Ventuz Help!
Hey,
just check out this VZA.. maybe it helps a bit
I created a "Font input Property" called one WingDings. For the Property i did chose "[wingdings, Bold, Italic".. as soon as it is pasted it will show as "wingdings, Bold, Italic"
just use the <WingDings> tag where you want it to have the different font or style and close the tag </WingDings> where it should end...
enjoy
regArts
enjoy
regArts
Got it!
as far as I can see, the material still works. The color you select in the font property replaces the base color. But you still get to setup the specular and emissive. However you can't select a spec color for each font color.
cheers,
cheers,
