HLSL node loses bindings on edit
lerou
Post by lerou » 13 Aug 2015, 14:08
so you've got your shader node with 50 parameters bound to other nodes. You edit the shader, upload it and on random occasion your HLSL node will lose all(!) bindings.
Re: HLSL node loses bindings on edit
Post by Karol » 14 Aug 2015, 10:52
So it is not possible to reproduce it?
lerou
Post by lerou » 14 Aug 2015, 12:57
unfortunately not. I thought it happens if you change some of the shader's parameters and therefore the interface... but it sometimes happens on a simple code change :/
