Is there an elegant way to exit Presenter?
robertwinter
Post by robertwinter » 17 Mar 2015, 22:58
Can Presenter be quit in a more elegant way than killing it in Task Manager? Can it be done via Remoting or some key sequence?
Re: Is there an elegant way to exit Presenter?
Post by chriss0212 » 18 Mar 2015, 00:18
like in most windows apps alt+f4 should work ;)
lerou
Post by lerou » 18 Mar 2015, 07:56
Alt-F4 works perfectly fine!
But... You can also use VMS to kill Ventuz. That's what the Config Editor does. That way you can put an exit button into your presentation :D
I've built such a kill button once. It even has a safety so it won't kill your designer ;)
cheers,
Killme.vpr
(14.45 KiB) Downloaded 509 times
Killme.vza
(12.48 KiB) Downloaded 523 times
florian
Post by florian » 18 Mar 2015, 10:29
You could use the command lines options
VentuzPresenter.exe -kill
http://www.ventuz.com/support/help/late ... tions.html
Florian
lerou
Post by lerou » 18 Mar 2015, 10:41
florian wrote:You could use the command lines options
l
That will kill running Ventuz instances when starting a new one - but not just kill the running one and return to the desktop.
cheers,
florian
Post by florian » 18 Mar 2015, 10:44
ok, my bad !
Florian
lerou
Post by lerou » 18 Mar 2015, 10:47
florian wrote:ok, my bad !
Still a good hint if someone starts a VPR via a batch file and needs to make sure, any running instance is killed first.
cheers,
