Is there an elegant way to exit Presenter?
robertwinter
Can Presenter be quit in a more elegant way than killing it in Task Manager? Can it be done via Remoting or some key sequence?
Re: Is there an elegant way to exit Presenter?
like in most windows apps alt+f4 should work
Alt-F4 works perfectly fine!
But... You can also use VMS to kill Ventuz. That's what the Config Editor does. That way you can put an exit button into your presentation
I've built such a kill button once. It even has a safety so it won't kill your designer
cheers,
cheers,
- Killme.vpr
- (14.45 KiB) Downloaded 519 times
- Killme.vza
- (12.48 KiB) Downloaded 540 times
You could use the command lines options
http://www.ventuz.com/support/help/late ... tions.html
VentuzPresenter.exe -killFlorian
That will kill running Ventuz instances when starting a new one - but not just kill the running one and return to the desktop.florian wrote:You could use the command lines optionslCode: Select all
cheers,
Still a good hint if someone starts a VPR via a batch file and needs to make sure, any running instance is killed first.florian wrote:ok, my bad !
cheers,
