U guys must have seen some motion sensing presentation show.Especially users can play with the visual text by their motion, to spray the text and recover...
How can I make this kind of effect ? Hope some idea can be shared here :p
thanks
allen
How can I make scatted text effect
Re: How can I make scatted text effect
As a first approach I would render the text to a Render Target and use bump maps and imported mesh deformation and explosions to create the effect coupled with a blur texture node. you might have to use two render targets. it should be doable. A custom shader would do the trick for sure.
Hi Chris,Christian Krix Schmidt wrote:As a first approach I would render the text to a Render Target and use bump maps and imported mesh deformation and explosions to create the effect coupled with a blur texture node. you might have to use two render targets. it should be doable. A custom shader would do the trick for sure.
It sounds unbelievable... could you plz share me a sample demo for your method ? thank u.
allen
Sorry i don't have the time at the moment to create that. I would have to play around as well.
See the attached VZA for a simple dissolve effect!
- DissolveEffect.vza
- (178.67 KiB) Downloaded 359 times
