How can I make scatted text effect
allen hyoga
Post by allen hyoga » 29 May 2014, 09:23
U guys must have seen some motion sensing presentation show.Especially users can play with the visual text by their motion, to spray the text and recover...
How can I make this kind of effect ? Hope some idea can be shared here :p
thanks
allen
allen hyoga
Re: How can I make scatted text effect
Post by allen hyoga » 29 May 2014, 09:53
Maybe I find a way to make it. lol:
allen
Post by Christian Krix Schmidt » 29 May 2014, 15:38
As a first approach I would render the text to a Render Target and use bump maps and imported mesh deformation and explosions to create the effect coupled with a blur texture node. you might have to use two render targets. it should be doable. A custom shader would do the trick for sure.
allen hyoga
Post by allen hyoga » 30 May 2014, 06:50
Christian Krix Schmidt wrote:As a first approach I would render the text to a Render Target and use bump maps and imported mesh deformation and explosions to create the effect coupled with a blur texture node. you might have to use two render targets. it should be doable. A custom shader would do the trick for sure.
Hi Chris,
It sounds unbelievable... could you plz share me a sample demo for your method ? thank u.
allen
Post by Christian Krix Schmidt » 30 May 2014, 08:06
Sorry i don't have the time at the moment to create that. I would have to play around as well.
Post by Karol » 03 Jun 2014, 10:37
See the attached VZA for a simple dissolve effect!
DissolveEffect.vza
(178.67 KiB) Downloaded 388 times
