is it possible at all to use a image-sequence (e.g. PNG) as the alpha of an alpha-mask-node.
a still of the sequence as alpha works fine. the sequence as animated image-sequence works fine as well.
how should one connect the nodes to be able to use an animated image-sequence as an animated alpha-sequence for a texture on a rectagle?
many thanks!
image sequence as alpha mask
Re: image sequence as alpha mask
The TextureMixer-Shader solves the question.
I wonder if it possible to create/compose the alpha for the Texture-Mixer-Shader.
Espacially combining greyscale+image and text would be great!
[AXIS] - [IMAGE] - [ALPHA] - [TEX MIX] - [RECT]
this [ALPHA]-node i want to compose
have tried RenderTarget and Hierarchy Container with no luck.
any help would be ver appreciated!
here is a test-project:
http://www.xup.to/dl,19250305/alphaText.zip/
Solution:
[IMAGE] - [RENDER TARGET TEXTURE] - [TEX MIX] - [RECT]
[RENDER TARGET] - [TEXT]
- [TEXTURE] - [RECT]
the easiest way is to use an image sequenz that has an alpha channel. In other words do not use images that are black and white, but use images that are white and alpha/transparent. If you then blend the textures by arranging the nodes as you see in the screenshot, you get the result that i guess you want.
Regards,
Götz
Regards,
Götz
- screen.png (8.65 KiB) Viewed 23141 times
