"Touch Button" node binding model
YW448505953
Post by YW448505953 » 19 May 2014, 07:50
"Touch Button" node on the model, a piece in the front block model; Why do some click can also activate the animation on this piece .
Re: "Touch Button" node binding model
Post by Karol » 19 May 2014, 10:11
Could you post your scene so we can reproduce it here?
YW448505953
Post by YW448505953 » 20 May 2014, 10:32
Click on the "Circle" and overlap model, how to don't touch of activation model. I want to activate Circle touch only, and does not activate the touch behind the Circle, the Circle made a similar to the effect of the mask.
Click model test .vza
(103.68 KiB) Downloaded 439 times
Post by Karol » 20 May 2014, 11:28
Hi!
If I understand you correctly, you want to activate the animation only on the circle (see attached scene).
For more complex setups you could also use the Touch Excluder node.
masked_touch.vzs
(8.16 KiB) Downloaded 422 times
YW448505953
Post by YW448505953 » 21 May 2014, 09:28
Even if I in front of the (circlel) added (Touch Excluder), also can't meet my requirements. Why (Touch Button) on the model, click (circlel) in some places can activate (mover). I demand: click anywhere (circlel) is not activated (mover). Very thank you for your always help!
masked_touch1.vzs
(8.46 KiB) Downloaded 389 times
