"Touch Button" node binding model
YW448505953
"Touch Button" node on the model, a piece in the front block model; Why do some click can also activate the animation on this piece .
- QQ截图20140519144808.png (3.43 KiB) Viewed 5030 times
Re: "Touch Button" node binding model
Could you post your scene so we can reproduce it here?
YW448505953
Click on the "Circle" and overlap model, how to don't touch of activation model. I want to activate Circle touch only, and does not activate the touch behind the Circle, the Circle made a similar to the effect of the mask.
- Click model test .vza
- (103.68 KiB) Downloaded 439 times
If I understand you correctly, you want to activate the animation only on the circle (see attached scene).
For more complex setups you could also use the Touch Excluder node.
- masked_touch.vzs
- (8.16 KiB) Downloaded 422 times
YW448505953
Even if I in front of the (circlel) added (Touch Excluder), also can't meet my requirements. Why (Touch Button) on the model, click (circlel) in some places can activate (mover). I demand: click anywhere (circlel) is not activated (mover). Very thank you for your always help!
- masked_touch1.vzs
- (8.46 KiB) Downloaded 389 times
