Two of the same node, connected to the same property
YanJie Xie
Post by YanJie Xie » 04 Sep 2013, 11:10
Hi guys,
How to make the node “PosX” on the left side of the Properties sign and node "RotY"on the left side of the attributes associated with it ?
The following is the reference node!
Best regards
yanjie xie
posx-posy.vza
(3.21 KiB) Downloaded 507 times
MartinT
Re: Two of the same node, connected to the same property
Post by MartinT » 04 Sep 2013, 13:37
i'm not sure if i got you right, but if you want to assign an input value of Node X to input value of Node Y, just drag and hover the desired property of Node Y over Node X until its properties appear. Then drop it onto the desired property.
Best regards
Martin
YanJie Xie
Post by YanJie Xie » 04 Sep 2013, 14:24
hi MartinT
That's a great option, thank you!
Best regards
yanjie xie
:D
