Hi guys,
How to make the node “PosX” on the left side of the Properties sign and node "RotY"on the left side of the attributes associated with it ?
The following is the reference node!
Best regards
yanjie xie
Two of the same node, connected to the same property
YanJie Xie
- posx-posy.vza
- (3.21 KiB) Downloaded 507 times
MartinT
Re: Two of the same node, connected to the same property
i'm not sure if i got you right, but if you want to assign an input value of Node X to input value of Node Y, just drag and hover the desired property of Node Y over Node X until its properties appear. Then drop it onto the desired property.
Best regards
Martin
Best regards
Martin
YanJie Xie
hi MartinT
That's a great option, thank you!
Best regards
yanjie xie
Best regards
yanjie xie
