How to make the movement of the two objects synchronized, in other words, when I rotate the red cube, the yellow one rotate too,or vice versus.
In order to express my meaning clearly, here is the attachment.
Thanks in advance!
Beckman
how to synchronize the two objects
beckman david
- synchornization of movement.vza
- (8.49 KiB) Downloaded 630 times
TobiTobsen
Re: how to synchronize the two objects
Please find two examples attached...
- synchornization of movement_3.vza
- (9.81 KiB) Downloaded 605 times
- synchornization of movement_2.vza
- (9.91 KiB) Downloaded 628 times
http://www.radar-touch.com
http://www.prime-touch.com
hi tobi
do you have it maybe as pro version? it is ple and i cant opnen it ;(
If he can't, you could remove your dongle, launch the PLE from the Start menu and request a license code. It is pretty fast.
TobiTobsen
Hi Christian,chriss0212 wrote:hi tobi
actually I just opened the example scene from Beckman and opened it without dongle. And there was neve an PLE registered for that machine I was using...
I was confused but just accepted it as a given fact
Cheers! Tobi
@christian: that was easy
@tobi: jepp....thats it
beckman david
Hi Tobi,
Thanks very much for your help.
As your guidance, I found that the rotation will be reverse if the parameter beyond 180, in other word, I want it to rotate upward, but in fact, it does it downward. This happens with the up and down rotation.
Cheers!
Beckman
Cheers!
Beckman
hi david,
this is a normal behavior in ventuz! you could buy a rotation module from echtzeitwerk to avoid this!
http://www.echtzeitwerk.de/portfolio/ez ... on-module/
