how to synchronize the two objects
beckman david
Post by beckman david » 27 May 2013, 11:36
How to make the movement of the two objects synchronized, in other words, when I rotate the red cube, the yellow one rotate too,or vice versus.
In order to express my meaning clearly, here is the attachment.
Thanks in advance!
Beckman
synchornization of movement.vza
(8.49 KiB) Downloaded 631 times
TobiTobsen
Re: how to synchronize the two objects
Post by TobiTobsen » 27 May 2013, 13:18
Please find two examples attached...
synchornization of movement_3.vza
(9.81 KiB) Downloaded 606 times
synchornization of movement_2.vza
(9.91 KiB) Downloaded 629 times
http://www.radar-touch.com
http://www.prime-touch.com
Post by chriss0212 » 27 May 2013, 14:53
hi tobi
do you have it maybe as pro version? it is ple and i cant opnen it ;(
Post by Christian Krix Schmidt » 27 May 2013, 15:10
If he can't, you could remove your dongle, launch the PLE from the Start menu and request a license code. It is pretty fast.
TobiTobsen
Post by TobiTobsen » 27 May 2013, 17:16
chriss0212 wrote:hi tobi
Hi Christian,
actually I just opened the example scene from Beckman and opened it without dongle. And there was neve an PLE registered for that machine I was using...
I was confused but just accepted it as a given fact :).
Cheers! Tobi
Post by chriss0212 » 27 May 2013, 17:20
@christian: that was easy ;)
@tobi: jepp....thats it ;)
beckman david
Post by beckman david » 28 May 2013, 10:28
Hi Tobi,
Thanks very much for your help.
As your guidance, I found that the rotation will be reverse if the parameter beyond 180, in other word, I want it to rotate upward, but in fact, it does it downward. This happens with the up and down rotation.
Cheers!
Beckman
Post by chriss0212 » 28 May 2013, 11:40
hi david,
this is a normal behavior in ventuz! you could buy a rotation module from echtzeitwerk to avoid this!
http://www.echtzeitwerk.de/portfolio/ez ... on-module/
