polar arrange
gabrielefx
polar arrange
Is it possible to array (arrange) a series of geometries along a circle and control the number, spaces between them and distance from the center dynamically?
Re: polar arrange
Do they need to have individual textures/shading?
TobiTobsen
Re: polar arrange
You can try to use the Spread node if all objects are indentic.
Otherwise a skript that controls the position etc of all objects.
http://www.radar-touch.com
http://www.prime-touch.com
gabrielefx
Re: polar arrange
yes buttons, same shape but different colorsChristian Krix Schmidt wrote:Do they need to have individual textures/shading?
TobiTobsen
Re: polar arrange
See example attached....
- PolarArranger.vza
- (33.55 KiB) Downloaded 595 times
gabrielefx
Re: polar arrange
thank you!TobiTobsen wrote:See example attached....
you created it now?
TobiTobsen
Re: polar arrange
You are welcome no big deal if you know polar and cartesian coordinates
Yes, it was raining all the time today, so time to play around with Ventuz
Re: polar arrange
and a more designer friendly version...because it is without a script
- PolarWithoutScript.vza
- (41.57 KiB) Downloaded 590 times
gabrielefx
Re: polar arrange
thank you my friends.
you are geniuses!
you are geniuses!
