polar arrange
gabrielefx
polar arrange
Post by gabrielefx » 26 May 2013, 12:09
Is it possible to array (arrange) a series of geometries along a circle and control the number, spaces between them and distance from the center dynamically?
Re: polar arrange
Post by Christian Krix Schmidt » 26 May 2013, 13:38
Do they need to have individual textures/shading?
TobiTobsen
Re: polar arrange
Post by TobiTobsen » 26 May 2013, 16:00
You can try to use the Spread node if all objects are indentic.
Otherwise a skript that controls the position etc of all objects.
http://www.radar-touch.com
http://www.prime-touch.com
gabrielefx
Re: polar arrange
Post by gabrielefx » 26 May 2013, 16:10
Christian Krix Schmidt wrote:Do they need to have individual textures/shading?
yes buttons, same shape but different colors
TobiTobsen
Re: polar arrange
Post by TobiTobsen » 26 May 2013, 17:54
See example attached....
PolarArranger.vza
(33.55 KiB) Downloaded 566 times
gabrielefx
Re: polar arrange
Post by gabrielefx » 26 May 2013, 19:19
TobiTobsen wrote:See example attached....
thank you!
you created it now?
TobiTobsen
Re: polar arrange
Post by TobiTobsen » 26 May 2013, 21:01
You are welcome no big deal if you know polar and cartesian coordinates :-)!
Yes, it was raining all the time today, so time to play around with Ventuz ;-).
Re: polar arrange
Post by chriss0212 » 27 May 2013, 06:17
and a more designer friendly version...because it is without a script ;)
PolarWithoutScript.vza
(41.57 KiB) Downloaded 561 times
gabrielefx
Re: polar arrange
Post by gabrielefx » 27 May 2013, 09:36
thank you my friends.
you are geniuses!
