do a layered - z loop without clipping ?
__G+A__
Post by __G+A__ » 17 Dec 2012, 11:06
with continously sending the front geometry behind all others in z with multi layerd alpha & transparenz ?
Re: do a layered - z loop without clipping ?
Post by chriss0212 » 17 Dec 2012, 21:40
hi
could you describe a bit more in detail what you like to do?
__G+A__
Post by __G+A__ » 18 Dec 2012, 10:33
hi christian,
thanx for re-asking . in attached picture you can see the "clipping" of the highest layer in hierarchy - when others go behind it in z space . how to avoyd this ?
Daniel Willer
Post by Daniel Willer » 18 Dec 2012, 11:24
You should try a Z-Sort node.
I've attached a small example scene.
Cherio
Z-Sort.vza
(64.01 KiB) Downloaded 473 times
__G+A__
Post by __G+A__ » 20 Dec 2012, 12:01
yuhuuu - so easy , thanx daniel
