do a layered - z loop without clipping ?
__G+A__
with continously sending the front geometry behind all others in z with multi layerd alpha & transparenz ?
Re: do a layered - z loop without clipping ?
hi
could you describe a bit more in detail what you like to do?
__G+A__
hi christian,
thanx for re-asking . in attached picture you can see the "clipping" of the highest layer in hierarchy - when others go behind it in z space . how to avoyd this ?
- z_layer_loop.png (13.77 KiB) Viewed 4656 times
You should try a Z-Sort node.
I've attached a small example scene.
Cherio
Cherio
- Z-Sort.vza
- (64.01 KiB) Downloaded 473 times
