objects scale problem
glaisser
Post by glaisser » 08 Oct 2014, 08:47
hello guys
well i make two rectangles and i want to make connection between them as parent child connection so i can use them in animation together as folding sides
but when i drag the child node to the parent node the model pop out the model postion and scale changes ????
what to do ????
glaisser
Re: objects scale problem
Post by glaisser » 09 Oct 2014, 09:22
Alex thanks for ur reply
it was my fault in the scale factor
well
i am new in ventuz and i have 3D background as 3Ds max and maya user
why its hard to add some tools like pivot points and interactive viewport like you can move and scale and rotate in the port screen
and also grid will be great and will make the work in ventuz more easily and its simple tools i guess for professional developers that creates ventuz
what do u think about that ?
ErikB
Post by ErikB » 09 Oct 2014, 09:54
Click on the render viewport, hit the tab key (or click the button on the side of the render viewport to activate the widgets) for SRT gizmos.
Pivot point - click on your axis in the content window and then go to properties and change rotation or scale center. Or click on the geometry and change alignment (left/right, top/bottom, center)
-E
glaisser
Post by glaisser » 09 Oct 2014, 11:29
heeeeeeeeeeey ErikB
well thank you so much thats really cooool
but there is an issue :D maybe its just for me
well when i grad the object on any axis as move or rotate or scale ....
the parameters in the properties does not change its keep the same numbers
its in the postion X,Y,z 0,0,0 and i am already moving the object
i am asking because i guess it will be useless for the animation if the parameters wont change while i am using the axis :D
sorry i am still new and the 3ds max or maya back ground affects me hhhhh
Götz_B
Post by Götz_B » 09 Oct 2014, 11:36
Turn on "Monitor Values" in the top right corner of the properties editor.
http://www.ventuz.com/support/help/late ... rentValues
The Animation Editor also has this button.
glaisser
Post by glaisser » 09 Oct 2014, 11:45
heeey GOTZ
Thank youuuuuuuuuuuuuuuuuuu so much :D
guys you all are great :D
i will continue learning and i will ask u more if there is anything else
