Remoting4 / Cluster.Snapshot Method
florian
Post by florian » 19 Jul 2014, 14:44
I'm looking for the Snapshot method
When testing, it always took render size image and not specified image in parameters
eg : clu(0).Snapshot(0, ImageFormat.PNG, 1920, 1080, Nothing, Nothing, Nothing, Nothing, Filter.High, True, TaskObj)
Any tips on that ?
So few examples from Ventuz... :(
Thanks,
Florian
Re: Remoting4 / Cluster.Snapshot Method
Post by Karol » 23 Jul 2014, 09:16
Hi Florian!
We are currently updating/fixing the Remoting API. So we will take a look on that.
Post by Karol » 23 Jul 2014, 15:54
It works for me (V 4.4.2).
And if you call the method with the parameter like above you get a snapshot of the whole render-output scaled down/up to 1920x1080.
florian
Post by florian » 28 Jul 2014, 08:34
I double check. The bug is really here
Here's snapshot output attached
and source code in vb.net
remotingQH v3 test snpashoot.zip (3.2 Mo) http://f.laboiteaslides.fr/89c8a/
Florian
Post by Karol » 28 Jul 2014, 10:04
Hi Florian!
Are you confused by the fact, that your snapshot is sometimes smaller than the specified 'width' and 'height'?
This happens because the snapshot image is not scaled up.
So if your Renderer has an output size of 1024x768 and you call Snapshot(0, ImageFormat.PNG, 1920, 1080, Nothing, Nothing, Nothing, Nothing, Filter.High, True, yop)
you will get an image of size 1024x768.
If your Renderer has an output size of 1920x1080 and you call Snapshot(0, ImageFormat.PNG, 1920, 1080, 0, 0, 960, 540, Filter.High, True, yop)
you will get an image of size 960x540.
Is this your problem?
florian
Post by florian » 28 Jul 2014, 10:08
Ok now i understand why it's not the correct size
This should be notified in the API documentation
Have a nice day,
Florian
Post by Karol » 28 Jul 2014, 10:17
Your are right :)
I will add this remark to the documentation.
A nice day for you, too!
