How to add output with initial value for script node
adhamdwikat
Post by adhamdwikat » 31 Mar 2014, 17:41
How to add output with initial value for script node or expression node
i used the custom model window to add output but i don't find any way to initialize the output value
for Integer its always 0 , some times i need to give it another initial values
Daniel Willer
Re: How to add output with initial value for script node
Post by Daniel Willer » 01 Apr 2014, 08:18
If you want to set an initial value in an expression you need to write an expresssion similar to that:
BoolInitialValue==true? InitialValue: A*B
Inside a Script node I am used to creat a Reset method with a SceneEvent node bound to it to set all my inital values.
Daniel
adhamdwikat
Post by adhamdwikat » 01 Apr 2014, 18:43
thanks,that works
