How to add output with initial value for script node or expression node
i used the custom model window to add output but i don't find any way to initialize the output value
for Integer its always 0 , some times i need to give it another initial values
Re: How to add output with initial value for script node
If you want to set an initial value in an expression you need to write an expresssion similar to that:
Inside a Script node I am used to creat a Reset method with a SceneEvent node bound to it to set all my inital values.
Daniel
BoolInitialValue==true? InitialValue: A*B
Daniel
