Render Target & 2 machines
joysprod
Post by joysprod » 04 Dec 2013, 13:08
I have a design I am working on with two machines giving me a total of 6 outputs...
All is fine if sending content straight to screens, As in AB&C
If I use a Render Target from the content, my outputs are completely wrong as in D&E
I have fixed this by re-mapping the individual polygons according to the machine ID, but was wondering if there is an easy fix I am missing using Viewport & Projection nodes? ? I realise that the aspect of machine 1 & 2 is not the same, and was wondering if that is what is throwing it out?
RenderTarget.vza
(23.41 KiB) Downloaded 343 times
Götz_B
Re: Render Target & 2 machines
Post by Götz_B » 04 Dec 2013, 15:30
there are some Nodes that need some extra attention when using the Render Setup.
http://www.ventuz.com/support/help/late ... itiveNodes
Just set the ScreenAligned property of the Render Target from inherit to no.
Regards,
Götz
joysprod
Post by joysprod » 04 Dec 2013, 16:15
Thanks Götz
I thought it was there somewhere! Was looking in the wrong place in the manual. Easy when you know how!!!
