radar touch and ventuz
javier
Post by javier » 14 Mar 2012, 10:30
Hello I am using a Touch Radar with Ventuz, but I get that Ventuz only respond as mouse emulation. Should respond as TUIO? What should be the Ventuz figuration?
Re: radar touch and ventuz
Post by chriss0212 » 14 Mar 2012, 19:55
hey javier
yes you should use tuio! tuio has to be enabled in the machine config of venuz what it should be in default.
but of course you need to setup the radarTOUCH software to send tuio to the ip adress of your ventuz pc and take care that you use on ventuz and rt the same udp port!
in basic thats all. but of course tuio will only work with the new touch nodes in ventuz not with mouse nodes!
if you need further informations.....let me know!
chriss
javier
Post by javier » 15 Mar 2012, 09:59
Thanks for your answer Chriss.
One more question. In an empty Ventuz scene, if I activate the button input diagnostics, should I see the touches of radar touch in the same way I see the mouse touches?
Post by chriss0212 » 15 Mar 2012, 14:21
hi javier
yes you should! tuio is enabled?
chriss
javier
Post by javier » 22 Mar 2012, 11:59
I've checked radar touch with the test program MultiBlobviz 3333, and it works, but when I use it with Ventuz not receive any information.
I attach two photos with Ventuz and RT settings and one of the lights that shine in the hardware.
TobiTobsen
Post by TobiTobsen » 13 Apr 2012, 20:58
You are Using an old radarTOUCH software version, please send us a mail to info@radar-touch.com. We will send you an update.
This might be helpful...
Tobi
http://www.radar-touch.com
http://www.prime-touch.com
Post by chriss0212 » 13 Apr 2012, 23:40
hi tobi
allready fixed :-)
chriss
TobiTobsen
Post by TobiTobsen » 15 Apr 2012, 15:45
Good Boy ;-)
gabrielefx
Post by gabrielefx » 12 May 2012, 12:38
I wrote to the radar touch company to know how euros costs this hardware and where purchase it.
No answer.
TobiTobsen
Post by TobiTobsen » 12 May 2012, 15:31
Hmm thats strange and very sad... maybe trying again or calling?
Please try again sending to info@radar-touch.com.
Or give us a call:
+49 (0)2266 4764-0
We are a pretty large company so someone will be available and answer every mail usually within one day.
When did you send it?
Tobi
