I would like to know if it's possible to use touch transformation when my finger is already pressed on the screen, but come from outside the geometry linked to the touch transform, then use it if my finger is inside (kill my english, i'll make an example)
example :
Finger start to touch screen on A, then i would like my finger slide to point B and touch transformation node moving (but it actually don't, i can see "touch enter", "touch leave" events sent but values don't follow finger).
(same problem if i use reset function while touching, touch will not work until i remove my finger from the screen and put it back into geometry)
Thanks.
