Touch from outside Geometry
sribas
Post by sribas » 25 Apr 2019, 13:05
Hello Guys !
I would like to know if it's possible to use touch transformation when my finger is already pressed on the screen, but come from outside the geometry linked to the touch transform, then use it if my finger is inside (kill my english, i'll make an example)
example :
Finger start to touch screen on A, then i would like my finger slide to point B and touch transformation node moving (but it actually don't, i can see "touch enter", "touch leave" events sent but values don't follow finger).
(same problem if i use reset function while touching, touch will not work until i remove my finger from the screen and put it back into geometry)
Thanks.
Re: Touch from outside Geometry
Post by Karol » 29 Apr 2019, 09:35
Hi scribas,
this is not possible with the current implementation of our touch system.
Post by chriss0212 » 14 May 2019, 08:40
It should be possible, with the TouchRipple in combination with some logig on TouchEnter of the Mesh.
Solution gets more complicated, if it is a multi touch screen, but still possible.
Greetings
Christian
