Particles Age Gradient
Naggar
Post by Naggar » 21 May 2018, 07:32
Hi guys.. Just have a small issue..
I want the particles to emit starting 0 alpha and fade in with age.. it works with the gradient, but it just flashes for a frame before the gradient takes its effect on them.. so basically every particle flashes white when it appears then goes 0 alpha to 100 to 0
is this a bug?
Re: Particles Age Gradient
Post by Karol » 23 May 2018, 11:17
Hi Naggar,
can you please post a small scene?
I cannot reproduce it here.
Naggar
Post by Naggar » 23 May 2018, 23:12
Yup..
File Attached
Test particle age Alpha.vza
(19.56 KiB) Downloaded 442 times
Post by Dennis » 31 May 2018, 12:37
basically we made a mistake and did not explain the system good enough (excuse me, it is really complex):
it is not meant to have a SPRITE/RENDERER INSIDE a simulation loop. basically you would just put the sprite renderer after the simulation loop.
In your case, the very first frame, renders a sprite (white flash) next frame THEN colorizes it.
But you want to: Emit, Colorize, Simulate, Render it
Hope that helps
Naggar
Post by Naggar » 08 Jun 2018, 19:38
Hi
Thanks.. that helped me understand the hierarchy of the attributes better :D
