Max on (Float)
davidicusrex
Max on (Float)
When setting the LoopEnd and End properties on a movie clip node, how to set it to Max when it is a float value? I put a digit in there like 10 so the clip stops at 10 seconds but when I put Max it does not accept the value. Any ideas? Thanks!
u-double-u
Re: Max on (Float)
hm, I guess I dont really get it. Just tried it myself. To set a loops end to max I just click that little circular arrow symbol next to the valuebox. No need to write anything myself.
cheers.
version 6.10 here
cheers.
version 6.10 here
davidicusrex
Re: Max on (Float)
The LoopEnd and End are being set from a database so the float value for LoopEnd and End are set automatically. I am trying to avoid having to set the length for each clip in the database so if there is no entry in the database I want Ventuz to set the value to Max. I cannot find a way to reset to Max without opening Designer and just do it from the database and using logic nodes in Ventuz.
Re: Max on (Float)
You have to use float.MaxValue for 'Max' and float.MinValue for 'Min'.
Sorry, this is not very intuitive.
