Hi guys
I found that when applying shadow on a 2 sided plane (Culling set to "none"), the shadow flickers when you cast the light from the back of the plane
Can you please test this from your side?
Create Floor and directional light with shadow, then create a rectangle with material draw mode (Draw All Faces / Culling:None) and pitch the light about 140 degrees.
frontfacing culling plane Shadow Bug
Re: frontfacing culling plane Shadow Bug
You mean when the backface is facing towards the camera and has the directional light hitting the frontface...
Anyway Yes it flickers.... because...
its a bug
Thanks i will submit a ticket
PS: the best is to reload the scene, it is completely broken!
regArts
its a bug
regArts
