I would like to read the VMS Projects search paths list to check if a path has been configured. I'd also like to modify the list and add a path if the desired path doesn't exist.
In Ventuz 6 it is possible to change the VMS config XML file (in C:\Users\Public\Documents\Ventuz6\Configuration\VMS) in which the VMS search paths are defined. Is there a similar location (file, registry, etc) where these paths are defined in Ventuz 5 and can be modified?
Location of VMS Projects configuration
Re: Location of VMS Projects configuration
Hi Etienne,
for V5 the according setting are stored in the IsolatedStorage: https://docs.microsoft.com/en-us/dotnet ... toragefile
I'm not sure if you are able to access this storage from another application at all. The 'file name' would be "config.xml".
