Designer crash on opening scene with Particle Stream and DisabledComputation
wiidee
Post by wiidee » 04 Dec 2019, 12:59
Hi
I cut down my scene to one Particle System node, with one Particle Stream, with Data Emitter loading particle positions from a text file.
Saving the scene with "DisableComputation" se to True makes the scene impossible to load again - Designer crashes on opening.
If DisableComputation is False, everything works well and the scene opens normally.
Ventuz 6.4.3.245 R26152, nothing in the log after crash.
Attaching a working scene and a crashing scene (archive)
thanks, adam
particle test - working.vza
(127.65 KiB) Downloaded 419 times
particle test - crashing - Particle System_DisableComputation.vza
(127.73 KiB) Downloaded 380 times
Jan
Re: Designer crash on opening scene with Particle Stream and DisabledComputation
Post by Jan » 04 Dec 2019, 16:54
Thanks for the report wiidee!
This was handed to our dev´s to further look into. Thanks for the attached scenes, those are helping big time.
