Layer property Filters
Naggar
Post by Naggar » 20 Oct 2019, 07:36
Hello
Would there be a way to create a filter for Bloom Effect,DoF,AmbientOcclusion?
This request is mainly for the bloom effect. Quite often I find myself using Bloom in a 3D Scene with camera animations, but sometimes I need to create a few footage popups in that scene, and I cant really use 3D reference Layer because there is no filter for bloom there either
In some cases I think this could save a lot of performance as well since we can use this method to reduce the use of Glare in FX nodes.
Re: Layer property Filters
Post by Dennis » 21 Oct 2019, 08:54
In first these FX work best in the HDR mod.
The reason for that is, that you "filter" the elements that should bloom/glare by shift them in the Higher Dynamic Range instead of "whats simply bright" gets bloom... in this case its "whats REALLY bright.. gets bloom".
Therefore you would adjust the "threshold to 0.0", "intensity to 3%" and only VERY bright elements will get a bloom applied.
I have attached a scene that shows the usage of the HDR, Pay attention to the "Emmisive Amount" and Bloom Settings.
RegArts
Bloom.vza
(41.39 KiB) Downloaded 517 times
Naggar
Post by Naggar » 12 Nov 2019, 11:35
That is good information. I didn't know that you could get anything brighter than white material with no light
Thanks a lot! :)
