I understand that Ventuz supports TUIO input, however I'd like to make my presentation output TUIO messages.
I’m using the Touch Ripple node to grab x/y and pressed touch data, but using an OSC Output node to send this as a TUIO message doesn’t work... I think I need a C# script to take this data and compute the correct /tuio/2Dcur message bundle and send it via UDP instead of using the OSC Output node.
Can anyone help or at least point me in the right direction?
TUIO Output C# Script?
Re: TUIO Output C# Script?
somehow you might be able to send correct TUIO Data with the OSC Output Node. The suggested way of taking a C# Script might be easier as you can set all OSC parameters by yourself and build bundles out of messages.
Ventuz even comes with its own OSC library ready to use. ==> Documentation can be found in the Start menu->Ventuz API and SDK
This Library works a little bit different then the reacTIVision one...
So my suggested way would be:
Implement the Ventuz.OSC namespace into your Script
Build the necessary messages (source, alive, set, fseq)
bundle them
and send them...
I don't know about the latest version of this API but always make shure to use asci strings. If Unicode is an option, it would only work within Ventuz...
Regards, Eric
bundle them
and send them...
Regards, Eric
Thanks Eric, much appreciated... I'll check out the Ventuz.OSC documentation and hopefully I can figure it out!
