Hello everyone..
Would it be possible to add a "Machine IP Address" output on the System ID node?
Machine IP output on System ID
Re: Machine IP output on System ID
+1
You can get the IP easily with a String expression using System.Net.Dns.GetHostEntry() and check the Address families of the result for "interNetwork"
==>Direct Access via SystemID would be nicer though
