VR machine + projection machine + cluster clock
Robert
Post by Robert » 06 Apr 2019, 16:32
Is it possible to synchronise a runtime running a VR configuration and another runtime running at 50fps for projection purpose ?
Regards,
Robert
Re: VR machine + projection machine + cluster clock
Post by Karol » 09 Apr 2019, 16:23
Hi Robert,
in the AV Outputs configuration of the Ventuz Config Editor there is a 'Frame Rate Multiplier': https://www.ventuz.com/support/help/lat ... Rates.html
Your setup is pretty suboptimal because the least common multiple of 50 and 90 is 450. The projection machine would need to validate 9 times and the VR machine 5 times per frame.
Robert
Post by Robert » 11 Apr 2019, 23:04
Hi Karol,
Thank you very much.
Regards,
Robert
Robert
Post by Robert » 19 May 2019, 20:28
Karol,
This setting seems to be too hard to synchronise for the cluster. I switched to a 60hz ×3 + 90hz ×2 mixed timings.
Regards,
Robert
Robert
Post by Robert » 11 Jul 2019, 13:12
Hi Karol,
Here is my feedback regarding this setup. Multiplying the frame rate introduce a performance issue. Validation time increases too much. As soon as we multiply the frame rate the rendering is not able to reach 90 fps.
Regards,
Robert
Post by Karol » 12 Jul 2019, 12:40
That's the drawback of synchronizing two machines with different FPS.
The scene needs to be 'lightweight' enough to render in the first frame tough it's validated multiple times per frame.
