Virtual webcam
Virtual webcam
Hello, I was wondering if it possible to use the feed of a virtual webcam on my machine as an input for the Live Video node. Thank you for your response
Re: Virtual webcam
basically you can use the Virtual Webcam module from OBS as a Live input in ventuz.. yes
regArts
regArts
Re: Virtual webcam
Good morning, should I able to see the obs virtual cam on the ventuz configuration editor? It doesn't appear as a device , appreciate the help!
Re: Virtual webcam
Hey again,
i counterchecked it with virtual cam and sadly it is not supported right now since it uses a directshow device instead of the needed media foundation device.
i have created a ticket for that! I understand it would be nice to have OBS by a VCam run with Ventuz, we need to be patient... maybe a dev will have a look at this sooner than later
meanwhile we could try to request a change in the virtual cam plugin for OBS to be able to use mediafoundation instead of DShow.
regArts
regArts
Re: Virtual webcam
Thank you Dee. I guess I will have to wait for this function. I m working on a project where I have to integrate snapchat camera into a ventuz scene.What I have found out was that the best way to do it is by selecting in obs the virtual snap cam then selecting in ndi scan converter the obs virtual cam and then finally bring that in Ventuz through a live video node!
