Multiple monitors
Multiple monitors
Hello , i would like to know if there is a way to render 1 vpr with 2 monitors without using Surround or Eyefinity, but only use multiple screens ?
Re: Multiple monitors
No there is not. Not from one machine. You need a unified canvas to spread the application across. So Eyefinity, nVidia Surround (GeForce) or nVidia Mosaic (Ti, Titan, Quadro) is required. You could however run the VPR in cluster mode from two machines. Each machine renders half the scene. Then the monitors do not have to be connected. Ventuz takes care of it. But you will need two machines and two licenses.
Chris
Chris
