In some cases it would be very usefull if we could run more ventuz instances on one pc.
For eg: i need to outputs and both outputs have a touch screen. It is a very simple scene and it budget for a second PC and a second Ventuz lic. is a KO for the project ;(
So it would be absolutly fantastic, if we could start Ventuz runtime twice but on different outputs!
Greetings
Christian
2 or more Ventuz Runtime instances on one PC
Re: 2 or more Ventuz Runtime instances on one PC
A workaround in Ventuz5/6 is an autoit script. First you need to make a copy of the VentuzPresenter.exe and rename it to VentuzPresenter_1.exe. If you start the presenter twice, you get an error.
This will open a presentation on screen 1 in director mode... will wait until its open... then move it to the second screen... and open the next presentation on screen 1
I think it only works in virtual fullscreen!
Greetings
Christian
Example()
Func Example()
Run('"C:\Program Files\Ventuz Technology Group\Ventuz 6\VentuzPresenter_1.exe" "D:\Ventuz\Projekte\Ventuz6\Test\Test.vzp" -log:0 -default:/zwei', "C:\Program Files\Ventuz Technology Group\Ventuz 6", @SW_SHOWMAXIMIZED)
WinWait("Test")
Sleep(1000)
Send("#+{Right}")
Sleep(1000)
Run('"C:\Program Files\Ventuz Technology Group\Ventuz 6\VentuzPresenter.exe" "D:\Ventuz\Projekte\Ventuz6\Test\Test.vzp" -log:0 -default:/eins', "C:\Program Files\Ventuz Technology Group\Ventuz 6", @SW_SHOWMAXIMIZED)
EndFunc ;==>Example
Greetings
Christian
