I'm sure this is in Ventuz and I'm just not seeing it.
I'm wanting to use 2 objects (really just their XYZ axis coordinates) to control a camera.
One object would give the camera its XYZ world coordinates.
Second object would inform the focal point the camera should be looking at.
The Pan and Tilt would be calculated from these 2 vertex position.
Greg
Setting Camera position and direction with 2 null objects
Re: Setting Camera position and direction with 2 null objects
set the camera to "look at" and you get both a position and a target. Bind them to whatever you need.
Huh...
Looks like I had my camera FOV Relation set to Layer
witched it back to None and like magic all the tracking started to work as expected.
Thanks for confirming that was the right way to do this.
