Osc between 6.1 and 4.9
Hi, I have a scene made in 4.9 and a new scene made in 6.1 and trying to send osc commands from 6 to 4, in presentation mode the osc does not work but when Ventuz 4 is running in designer mode it receives the osc commands, is there something different when running in presentation mode with osc.
Re: Osc between 6.1 and 4.9
Hi Hashim,
please check you firewall!
Probably it's blocking the communication with the Presenter.
Generally there is no difference between Designer and Presenter when it comes to how nodes work - it's the same code.
Sure, that it is only in presentation mode? Do you use Strings? Maybe that's the problem, because old Ventuz is using Strings different!
Greetings
Christian
Greetings
Christian
