Hey!
Is there any way to extrude some geometry from the IPP Effects inside hdr scene layer ?
I have a virtual set with some IPP Effects like glare and color correction, but I want to extrude some geometry so they'll not be effected by the Layers IPP Effects.
Thanks.
Extrude geometry from Layers IPP Effects
Re: Extrude geometry from Layers IPP Effects
Do you mean exclude by any chance? Yes, you can. Simply move the effects from the layer level inside it. Use the Effect FX node inside your hierarchy. This let's you control where you want to use effects specifically.
