Hey!
I'm new with ventuz, so I can't find any way to chroma key my green screen footage
I want to know to to chroma key a green screen footage with ventuz and which node I should use to do so.
chroma key, keying with ventuz
Re: chroma key, keying with ventuz
this is a effect you can use within the layer, there is no node necessary.
thanks! it worked with a 2d layer, but I want this layer to be in a 3d scene (as a virtual set with moving camera). So how can I achieve that ?
Hey,
you can add this EFFECT, since it is an IPP, as well onto a 3d Layer..
regArts
regArts
If you need it within a 3D tree, you can always use the FX node in the hierarchy tree, too... but as Dennis says, normally, you would want this as a layer effect.
