Can you add it the next minor and major version of ventuz ?The new version of NDI Scan Converter provides vastly improved image quality and much, much more. The GPU is now used to capture the screen, and handles the lion’s share of color conversion, processing and NDI transmission. You can now capture all of your system’s desktops in real-time, at full 60Hz and with almost no CPU usage.
NDI 3.5
NDI 3.5
Re: NDI 3.5
The NDI scan converter will just be a tool you can download.
I bet that Ventuz is already doing the color conversion internally on the GPU.
Also in theory you could probably obtain the Processing.NDI.Lib.x64.dll from the new v3.5 SDK (when it will be released after NAB) and update that to use with Ventuz. I bet it's gonna be compatible as it normally tends to ship that way. Not that would render you with an unsupported system naturally
so better to wait for the Ventuz guys to fix that in their installer.
