Hi Ventuz Team,
Thank you for Ventuz X.
It is so much fun to explore new features that are hiding inside UI and figuring out the way it works with knowledge we have.
Here is my small list of bugs :
1. Ctrl+Shift+E doesn't work for Scene Data to create an Event. It works as a hotkey to show annotations.
The select/collapse behavior of Material Stages, Particle System Modules and Effects is fixed for the next release, thanks again for the Feedback on this.
I was playing today with Gradient and I found that.
When I selected one of the value (for example "Position") and moved it to another color point, selection didn't go away. It kept same value and applied to the last selected color point after been unselected.
With complex gradients it is ruining work.
Direct at the beginning i tryed to add a node over the alphabetical mode ... i can not type in over keyboard. The categroized toolbox works with the keyboard.
In the alphabetical view i can click on an arrow on the upper right and type in my node. after reopen the toolbox the program shows the list of nodes depanding on my input.
Hi Phillip, had the same issue.
Mine was caused by the known UI scaling issues (4k Laptop scaled to 200%)
Scaled down to 100% -> UI for Ants but alphabetical mode works.
